Cancel in "user_input"
dmaon
Post by dmaon »
How do I check in a mcro if the user pressed Cancel in a dialog created by "user_input"?
By the way - did you succeed to recreate the bug were the program returned a wrong left marked column - as I described in response to you?
    -- the initial value
    local nill = ""
    -- ask for a user supplied decimal number
    local value = user_input("Some Value:", nill)
    if string.len(value) > 0 then
      message("User value was '" .. value .. "'.")
      message("Operation cancelled by user!")
Unfortunately I could not replicate the bug at this end :(
