I'm evaluating Zeus as a replacement to CodeWright for our organization.
Before we commit to Zeus (which is the best low cost editor I looked at so far), I'd like to get some feedback on some missing/broken features of Zeus. They are listed in order of importance from top to bottom.
1. Column mode - edit multiple lines at once a-la UltraEdit.
2. Diff between buffers, not files.
3. Direct access to external diff application.
4. Set font for printing.
5. Tab dragging (I know there are workaround kludges).
6. Outline templates (regex) a-la CodeWright.
2. Full help - several HELP buttons lead to the index page.
None of these issues (with the exception of #1) is a major issue...
Amit
Features
Unfortunately these features are not currently provided by Zeus
Using the Options, Editor Options menu, in the Miscellaneous section there is an option to define an external difference command. With this command line can defined you can run the external difference from the Zeus File Difference dialog using the View External button.
You could also run the difference using a macro for example, something like this:
-- get the file details
local file1 = get_global_string("FILE1_DIFFERENCE", true)
local file2 = get_global_string("FILE2_DIFFERENCE", true)
-- ask for a user for a command line
file1, file2 = user_input("File #1:", file1, "File #2:", file2, "File Difference")
if (string.len(file1) == 0) and (string.len(file2) == 0) then
return 1
-- save the details for next time
set_global_string("FILE1_DIFFERENCE", file1, true)
set_global_string("FILE2_DIFFERENCE", file2, true)
-- setup command control falgs (see the Zeus Macro help for details)
local flags = 2+4+32
-- use the xDiff.exe found in the Zeus directory
local dir = macro_tag("$zd")
-- the diff command
cmd = "xDiff.exe " .. file1 .. " " .. file2
--debug_enable();
--debug_output(cmd);
-- run diffeence command
system(cmd, dir, flags)
Use the Option, Editor Options menu, Fonts section and select the Printer from the list of Display Views.
At present that is all there is
I am not familiar with this feature. The Zeus regexp is based on the Unix/Perl engine.
The Zeus help files need lots of work
Regards Jussi Jumppanen
Thanks for the quick response
Outline mode allows the user to see all functions/procedures/macros or whatever (similar to the class browser) in a separate pane, and of course jumps to the right spot upon a click. It differs from the class browser in that it's general - the user can define what makes a function (or any other item) using regex and the editor scans the current file for these.
Amit
Are there plans to add this functionality? I'd say this comes high on many user's requests.1. Column mode - edit multiple lines at once a-la UltraEdit.
Amit
This feature is on the Zeus todo list, but as this list is very long, I'm not sure exactly when this feature will make it's way into Zeus
The View, Function List menu does exactly this. It will search the current file for the Function regular expression defined in the General section of the Options, Document Types menu
Cheer Jussi
These are used by the Zeus compiler features to identify the line number and filename from a given line of text.what do the other regex entries on the General page do?
Zeus has internal defaults for all three of these regexp's and they seem to handle most languages/compilers, so in general these regexp's can be left blank.
