Zeus for Windows 3.97x Patch
Locked
Post by jussij » Wed Jun 10, 2015 7:20 am
This message is to announce the release of the latest Zeus 3.97x version.
The latest Zeus 3.97x patch can be found here: http://www.zeusedit.com/z300/ze397x.zip
NOTE: This is a free upgrade for any Zeus 3.97t (or higher) user.
If your registration key predates the Zeus 3.97t release (i.e August 2013) then that key will not work with this version of Zeus.
  3. Run the latest Zeus 3.97x installer and install the software into the original Zeus directory of step 2.
Locked
