Using the Dscanner (D Language) inside Zeus
The Dscanner is a tool designed to analyzing D source code.
NOTE: Other Zeus, D language specific features can be found here:
Using the dfmt with Zeus
Using the D Programming Language with Zeus
Using the DCD with Zeus
These are just some of the features this tool has to offer:
Syntax Check
The "--syntaxCheck" or "-s" option prints a listing of any errors or warnings found while lexing or parsing the given source file.
Style Check
The "--styleCheck" or "-S" option runs some basic static analysis checks against the given source files.
Find Declaration
The "--declaration" or "-d" options allow you to search for a symbols declaration.
Example of Using Find Declaration
Assume this file is open:
Dscanner\astprinter.d
In that file there are these lines of code:
override void visit(const AddExpression addExpression)
With the cursor placed on the AddExpression word, running the Find Declaration tool results in this output:
.\libdparse\src\std\d\ast.d(371:13)
Double clicking on that line of output loads the ast.d file and places the cursor on this line of code in that file:
final class AddExpression : ExpressionNode
Zeus Configuration
To use the Dscanner from inside Zeus you will need to do the following:
1) Download the source code from the Dscanner home page.
2) Build the dscanner.exe and copy the executable to this folder (which will issure it is in the PATH):
3) Edit the D Document Type and in the Tools section add the three tool configurations described below.
     Menu Test: Syntax Check
  Program Name: dscanner.exe
     Arguments: --syntaxCheck "$fn"
Work Directory: $fdd
    (o) Run Hidden
    [x] Capture Standard Output
    [x] Capture Standard Error
     Menu Test: Style Check
     Arguments: --styleCheck "$fn"
    (o) Run Hidden
     Menu Test: Find Declaration
     Arguments: --declaration $wex
    (o) Run Hidden
To use these tools just open a file containing D source code and select the tool from the Tools menu.
In the following post find details on how to wrap these calls to the Dscanner tool inside a Zeus macro.
By using a macro allows you to do things like configure Zeus to run these style checks each time the file is saved or to have these checks run using a keyboard key combination.
Below are Zeus Python scripts that wrap the Dscanner functionality inside a macro.
By running Dscanner from inside a macro it is easier to bind the functionality to the keyboard or to have the macro run on particular events like the file save event.
The four files below should be saved to the Zeus zScript folder.
dscanner_syntax_check.py
#        Name: Dscanner Style Check
#      Author: Jussi Jumppanen
#    Language: Python
# Description: This Zeus macro uses the Dscanner utility to implement
#              style check feature.
#                  https://github.com/Hackerpilot/Dscanner
#              For this macro to work the Dscanner executable needs to be
#              in the Zeus install folder or in the PATH.
import zeus
import dscanner_code
def key_macro():
    if zeus.is_document() == 1:
        # save the current file
        result = zeus.FileSave()
        if (result == 1):
            # use the currently active document
            file_name = zeus.macro_tag("$fn")
            # do the style check
            dscanner_code.styleCheck(file_name)
        else:
            zeus.message("The operation cancelled by user.")
            zeus.beep()
key_macro() # run the macro
dscanner_style_check.py
#    Language: Python
import zeus
def key_macro():
        if (result == 1):
        else:
            zeus.beep()
dscanner_find_declaration.py file
#        Name: Dscanner Find Declaration
#    Language: Python
#              find declaration feature.
import os
import zeus
def key_macro():
    symbol = zeus.macro_tag("$wex")
    if len(symbol) > 0:
        directory = zeus.macro_tag("$fdd")
        # change to the directory of the active file
        os.chdir(directory)
        # try to find the symbol
        dscanner_code.findDeclaration(symbol)
    else:
        zeus.message("No symbol found under the current cursor.")
        zeus.beep()
The script file below holds common code that is used by the three previous scripts.
dscanner_code.py file
#        Name: Dscanner Common Code
#    Language: Python
# Description: This macro file contains the common code needed to make Zeus
#              work with the Dscanner utility.
import os
import re
import time
import zeus
import subprocess
def outputFileName(file_name):
    file_name_err = file_name + ".ztow"
    # check that the file constains no whitespace
    if (file_name.find(' ') <> -1):
        file_name = "\"" + file_name + "\""
        file_name_err = "\"" + file_name_err  + "\""
    return file_name, file_name_err
def runCommand(command, file_output):
    # remove any previous output file
    if os.path.exists(file_output):
        os.remove(file_output)
    #  1 - save the document before running the program
    #  2 - capture any standard output generated by the program
    #  4 - capture any standard error generated by the program
    #  8 - ask for additional arguments
    # 16 - the program will use the MS-DOS command interpreter (ie. dir *.* etc)
    # 32 - wait for the program to complete (the ESC key will cancel the wait)
    # 64 - run the program in a visible DOS session (otherwise runs hidden)
    flags = 1+16+32
    # run the command
    result = zeus.system(command, "", flags, "shit")
    #zeus.message_box(0, command)
    have_errors = 0
    # che3ck for any error output details
        if os.stat(file_output).st_size > 0:
            have_errors = 1
    return have_errors
def runCommandEx(command):
    # initialise the startup info to run hidden
    info = subprocess.STARTUPINFO()
    info.dwFlags |= subprocess.STARTF_USESHOWWINDOW
    info.wShowWindow = subprocess.SW_HIDE
    result = ""
    error  = ""
    # run the command and capture the output
    try:
        # run the command line
        p = subprocess.Popen(command, stderr=subprocess.PIPE, stdout=subprocess.PIPE, startupinfo=info)
        # wait for the process to return
        while p.poll() is None:
            time.sleep(0.20)
        # get the process output
        result = p.stdout.read()
        error  = p.stderr.read()
    except Exception, e:
        zeus.message_box(0, "Unexpected Error: " +  str(e) + "\n\nCommand: " + command + "\n\nMake sure dscanner.exe is in the PATH.", "Dscanner")
        result = ""
    #zeus.message_box(0, "Command: " +  str(command) + "\n\nResult: " + str(result) + "\n\nError: " + str(error))
    return error, result
# Style Check: dscanner.exe --styleCheck sourcefile.d
# The "--styleCheck" or "-S" option runs some basic static analysis checks
# against the given source files.
def styleCheck(file_name):
    # file details
    file_name, file_name_err = outputFileName(file_name)
    # command to write details to error output file
    command = "dscanner.exe --styleCheck " + file_name + " > " + file_name_err + " 2>&1 "
    have_errors = runCommand(command, file_name_err)
    # check for errors
    if have_errors:
        # display the errors in a tool window
        zeus.file_open_tool(file_name_err, "Dscanner Style Check")
    else:
        zeus.message("Style check found no errors.")
# Syntax Check
# The "--syntaxCheck" or "-s" option prints a listing of any errors or
# warnings found while lexing or parsing the given source file.
def syntaxCheck(file_name):
   # file details
   command = "dscanner.exe --syntaxCheck " + file_name + " > " + file_name_err + " 2>&1 "
   # run the command
   # check for errors
   if have_errors:
       zeus.file_open_tool(file_name_err, "Dscanner Syntax Check")
   else:
       zeus.message("Syntax check found no errors.")
def findDeclaration(symbol):
    # Find Declaration
    # The "--declaration" or "-d" options allow you to search for a symbols declaration.
    command = "dscanner.exe --declaration " + symbol
    # run the command
    error, result = runCommandEx(command)
    # see if we had success and a result
    if (len(error) == 0):
        # Output example:
        # .\libdparse\src\std\d\ast.d(371:13)
        match = re.search("(.*)\((.*)\:(.*)\)", result)
        if match:
            # get the details
            file_name   = match.group(1)
            line_number = match.group(2)
            column      = match.group(3)
            # open the file
            zeus.file_open(file_name, "Dscanner Syntax Check")
            # locate the symbol in the file
            zeus.set_line_pos(line_number)
            zeus.set_cursor_pos(column)
            zeus.message("Found symbol: " + symbol)
        else:
            zeus.message("No delcaration found for symbol: " + symbol)
    else:
        zeus.message_box(0, command + "\r\n" + error, "Find Declaration Error")
        zeus.message("Unexpected error running command: " + command)
