Zeus for Windows 3.97c Patch
Locked
Post by jussij » Fri Jun 04, 2010 12:15 am
To all registered Zeus Version 3.96 and 3.97 users,
The latest Zeus for Windows 3.97c patch can be found here: http://www.zeusedit.com/z300/ze397c.zip
As always, backup your current install before applying any patch.
INSTALLATION NOTES:
To install the patch do the following:
  • Make a full backup copy of the current Zeus installation directory
  • If you are running Vista or Windows 7 follow the instructions found here
  • Unzip the patch file to write over the current set of exe and dlls files
  • Start Zeus and re-enter your registration details
  • Display the About dialog using the Help, About menu
  • Ensure the version listed is 3.97c
  • Ensure the registration details displayed are still correct
Regards Jussi Jumppanen
Locked
