keyproc folding
gwgs
keyproc folding
Post by gwgs » Mon Jun 02, 2008 10:49 pm
Keyproc folding not working.
Also forms /... folding entire program, not just to next /*
Comments // folding entire program too
If comments // in program, folding options after it are disabled until next form /... /* combination.
eg, using sample code.
can fold forms /sampleform, /header, /body
there are 3 separate comment lines early on after the /*
all folding is disabled until /sampleform2 & /*
Sorry for the delay in posting, I thought I posted last week but it didn't go through for some reason (probably didn't post it after previewing it).
Grant
Post by jussij » Mon Jun 02, 2008 11:31 pm
I downloaded the xFolder.dll found here: http://www.zeusedit.com/z300/xFolderPF.zip
Then using your sample code this dll folds this code:
 keyproc key.escape
    abort
 keyproc key.field
    backfield
 keyproc key.return
    ifwindow eq testform2.1 begin
       clear tsetfile
       testfile.code=testfile.1
       find eq testfile by index.1
       [found] entdisplay testfile
down to this:
+ keyproc key.escape ... return
+ keyproc key.field  ... return
+ keyproc key.return ... return
Anys this code:
  /sampleform
  enter this: __________
             _[_ all correct?
  /header
      sample report
  code  description
  /body
  _____ ___________
  // include common variables
  #include common.inc
  // define testind if required
  #IFNDEF testind
  indicator testind
  #ENDIF
  indicate tesetind false
  // reset teststr or define teststr if required
  #IFDEF teststr
  teststr=""
  #ELSE
  string teststr 30
  #ENDIF
  function testfunction string instr returns string
  integer ctr
  result=""
  for ctr from length(instr) to 1 step -1
  result=result+mid(instr,1,ctr)
  loop
  end_function
folds down to this:
 + /sampleform ... /*
   #include common.inc
   #IFNDEF testind
   indicator testind
   #ENDIF
   #IFDEF teststr
   teststr=""
   #ELSE
   string teststr 30
   #ENDIF
   integer ctr
   result=""
   loop
   end_function
I'm not sure what you mean by this :?:
Isn't the // just a line comment :?: The folder will ignore anything after the line comment.
Sorry, i'm confused :?
gwgs
Post by gwgs » Tue Jun 03, 2008 1:29 am
After doing some more testing I found the following.
Yes keyproc folding works, but the folding bar doesn't show that it can be folded until you edit the sample code around it, then it gets re-detected that it can be folded.
yes // is a line comment, anything after that is a comment
I found that when there is a line coment at column 1, the code folding detection doesn't work except for the forms /.... /* and the begin ... end delimters. All other code folding breaks aren't showing or working until they are re-detected.
Hope that's clearer.
Grant
gwgs
Post by gwgs » Tue Jun 03, 2008 1:32 am
On the code folding of forms and line comments....
using the sample code, when /sampleform is folded, the entire program down to the last 3 comment lines are folded into a single line.
same goes for /header and any // lines that start at column 1
hope that is clearer.
Grant
Post by jussij » Tue Jun 03, 2008 2:49 am
For me this is working perfectly. This very strange :?
Which version of Zeus is shown in the help about dialog :?:
Again I don't see this :(
For me I can have this code:
   #IFNDEF testind
   indicator testind
   #ENDIF
and it will fold to this:
 + #IFNDEF testind ... #ENDIF
using the sample code, when /sampleform is folded, the entire program down to the last 3 comment lines are folded into a single line. same goes for /header and any // lines that start at column 1
Unfortunately I don't see that :? I have update my previous posting to show exactly what I am seeing.
I am not really sure why the folding is working for me and not for you. I would suggest making sure you don't have a stray version of the xFolder.dll floating about.
One thing you could try is editing the xFolder.ini file and add .log to the PowerFlex folder entry. Then if you create a log file and past some Poerflex code into the file it will fold.
This will check to see if the issue is document type related.
gwgs
Post by gwgs » Tue Jun 03, 2008 4:05 am
I have zeus v3.96p
I added log to the powerflex entry in xfolder.ini I still get the same result.
sample.log as below
/sampleform
           _[_ all correct?
/header
    sample report
code  description
/body
_____ ___________
#include common.inc
#IFNDEF testind
   indicator testind
#ENDIF
#IFDEF teststr
   teststr=""
#ELSE
   string teststr 30
#ENDIF
   integer ctr
   result=""
   loop
end_function
procedure testprocedure string instr
   integer ctr
   ctr=length(instr)
   while ctr>0
      showln mid(instr,1,ctr)
      ctr=ctr-1
   until ctr=0
end_procedure
   entergroup
      accept sampleform.1  {capslock}
      accept sampleform.2  {checkbox}
   endgroup
   teststr=sampleform.1
   for ctr from 1 to length(teststr) step 1
      showln mid(teststr,1,ctr)
   loop
   switch sampleform.2
      when 1
         showln "YES"
      otherwise
         showln "NO"
   endswitch
   open testfile
   report testfile by index.1
      section header
         output header
      section body
         print testfile.code
         print testfile.desc
         output body
#include RPTKEY.inc
   reportend
   showln testfunction(sampleform.1)
/sampleform2
   code:        _____
   description: ___________
   enter testfile
      entry testfile.code testform2.1 {capslock}
      entry testfile.desc testform2.2
   enterend
keyproc key.escape
   abort
keyproc key.field
   backfield
keyproc key.return
      clear tsetfile
// general code formating comments:
// there are no case restrictions or strict formating other than syntactical restrictions
// the above code could have been all uppercase, without any indentation
I just created a clean install of Zeus and it works as you describe. once I copied my zconfig folder over it stopped working :( I'll investigate the differences and see if I can find out what's causing it.
Grant[/code]
Post by jussij » Tue Jun 03, 2008 4:23 am
I just created a clean install of Zeus and it works as you describe. once I copied my zconfig folder over it stopped working.
If you send me the zConfig files as a zip file attachment I would be happy to take a look what is going wrong ;)
Just use the e-mail button bellow and put the word Zeus in the subject text.
Post by jussij » Tue Jun 03, 2008 6:06 am
The reason your comments are not folding correctly is because the Allow nested comments option is checked in the document type setting control ;)
I made some minor changes to the code so you should also get the latest xFolder.dll found here: http://www.zeusedit.com/z300/xFolderPF.zip
gwgs
Post by gwgs » Tue Jun 03, 2008 8:16 am
Thanks Jussi, that was it :D the code folding works great.
Grant
Post by jussij » Wed Jun 04, 2008 4:16 am
Hi Grant,
I made some additional minor enhancements to the folder so you should also get the latest xFolder.dll found here:
gwgs
Post by gwgs » Tue Jun 10, 2008 4:48 am
works well
Thanks Jussi
Grant
