Zeus for Windows 3.97z Patch
Locked
Post by jussij » Wed Sep 30, 2015 10:31 am
This message is to announce the release of the latest Zeus 3.97z version.
The latest Zeus 3.97z patch can be found here: http://www.zeusedit.com/z300/ze397z.zip
NOTE: This is a free upgrade for any Zeus 3.97t (or higher) user.
If your registration key predates the Zeus 3.97t release (i.e August 2013) then that key will not work with this version of Zeus.
  3. Run the latest Zeus 3.97z installer and install the software into the original Zeus directory of step 2.
  4. Copy over the zConfig directory from now renamed directory of step 2 and paste the directory into the new Zeus installation directory.
  5. At any stage should you then wish to revert back to the older release, just delete the latest version and undo the rename from step 2.
Locked
