Zeus for Windows 3.97y Patch
Locked
Post by jussij » Wed Jul 01, 2015 12:07 pm
This message is to announce the release of the latest Zeus 3.97y version.
The latest Zeus 3.97y patch can be found here: http://www.zeusedit.com/z300/ze397y.zip
NOTE: This is a free upgrade for any Zeus 3.97t (or higher) user.
If your registration key predates the Zeus 3.97t release (i.e August 2013) then that key will not work with this version of Zeus.
  3. Run the latest Zeus 3.97y installer and install the software into the original Zeus directory of step 2.
Locked
