Zeus for Windows 3.97w Patch
Locked
Post by jussij » Mon Jun 01, 2015 9:57 am
This message is to announce the release of the latest Zeus 3.97w version.
The latest Zeus 3.97w patch can be found here: http://www.zeusedit.com/z300/ze397w.zip
NOTE: This is a free upgrade for any Zeus 3.97t (or higher) user.
If your registration key predates the Zeus 3.97t release (i.e August 2013) then that key will not work with this version of Zeus.
  3. Run the latest Zeus 3.97w installer and install the software into the original Zeus directory of step 2.
Locked
Users browsing this forum: No registered users and 3 guests
