Zeus for Windows 3.97v Patch
Post by jussij » Thu Jan 15, 2015 10:08 pm
This message is to announce the release of the latest Zeus 3.97v version.
The latest Zeus 3.97v patch can be found here: http://www.zeusedit.com/z300/ze397v.zip
NOTE: This is a free upgrade for any Zeus 3.97t (or higher) user.
If your registration key predates the Zeus 3.97t release (i.e August 2013) then that key will not work with this version of Zeus.
  3. Run the latest Zeus 3.97v installer and install the software into the original Zeus directory of step 2.
