Zeus for Windows 3.97t Upgrade Release
Locked
Post by jussij » Sat Jul 26, 2014 2:30 am
This message is to announce the release of the latest Zeus 3.97t versions.
Here is what's new in this release: http://www.zeusedit.com/whatsnew.html
The latest Zeus for Windows 3.97t patch can be found here: http://www.zeusedit.com/z300/ze3997t.zip
VERY IMPORTANT NOTE:
If your registration key is dated 2014 or later this is a free upgrade.
If your registration key is dated 2013 or earlier then that key will not work with this version of Zeus :!:
For these older registration keys please install the Zeus 3.97p found here: http://www.zeusedit.com/zforum/viewforum.php?f=6
If you wish to trial/install this latest version you need to do the following:
  1. Make sure you have a full copy of your current registration code just in case ;)
  2. Also make full backups of your current Zeus installation including both the Zeus bin folder and the zConfig folders.
  3. Move you current installation out of the way and run the full installer from the download page.
  4. To copy over your current settings refer to this link: http://www.zeusedit.com/zforum/viewtopic.php?t=6406
  5. Don't forget to do the full backup before running the installer.
Locked
