Zeus for Windows 3.97s Patch
Post by jussij » Sat Apr 05, 2014 5:21 am
This message is to announce the release of the latest Zeus 3.97s version.
The latest Zeus 3.97s patch can be found here: http://www.zeusedit.com/z300/ze397s.zip
NOTE: This is a free upgrade for any Zeus 3.97p (or higher) user.
If your registration key is dated 2012, 2011 or earlier then that key will not work with this version of Zeus.
  3. Run the latest Zeus 3.97s installer and install the software into the original Zeus directory of step 2.
