Zeus for Windows 3.97r Patch
Post by jussij » Fri Jan 17, 2014 4:10 am
This message is to announce the release of the latest Zeus 3.97r version.
The latest Zeus 3.97r patch can be found here: http://www.zeusedit.com/z300/ze397r.zip
NOTE: This is a free upgrade for any Zeus 3.97p (or higher) user.
If your registration key is dated 2012, 2011 or earlier then that key will not work with this version of Zeus.
  3. Run the latest Zeus 3.97r installer and install the software into the original Zeus directory of step 2.
