Zeus for Windows 3.97q Patch
Locked
Post by jussij » Mon Sep 30, 2013 12:20 am
This message is to announce the release of the latest Zeus 3.97q versions.
The latest Zeus 3.97q patch can be found here: http://www.zeusedit.com/z300/ze397q.zip
VERY IMPORTANT NOTE:
NOTE: This is a free upgrade for any Zeus 3.97p user.
If your registration key is dated 2012, 2011 or earlier then that key will not work with this version of Zeus.
  3. Run the latest Zeus 3.97q installer and install the software into the original Zeus directory of step 2.
Locked
