Zeus for Windows 3.97o Patch
Locked
Post by jussij » Wed Jan 16, 2013 11:19 am
This message is to announce the release of the latest Zeus 3.97o versions.
The latest Zeus for Windows 3.97o patch can be found here: http://www.zeusedit.com/z300/ze397o.zip
VERY IMPORTANT NOTE:
  3. Run the latest Zeus 3.97o installer and install the software into the original Zeus directory of step 2.
Locked
