Zeus for Windows 3.97n Patch
Post by jussij » Wed Aug 22, 2012 7:39 am
This message is to announce the release of the latest Zeus 3.97n versions.
The latest Zeus for Windows 3.97n patch can be found here: http://www.zeusedit.com/z300/ze397n.zip
  3. Run the latest Zeus 3.97n installer and install the software into the original Zeus directory of step 2.
