Zeus for Windows 3.97l Patch
Locked
Post by jussij » Sun Jun 24, 2012 5:48 am
This message is to announce the release of the latest Zeus 3.97l versions.
The latest Zeus for Windows 3.97l patch can be found here: http://www.zeusedit.com/z300/ze397l.zip
VERY IMPORTANT NOTE:
  3. Run the latest Zeus 3.97l installer and install the software into the original Zeus directory of step 2.
Locked
