Zeus for Windows 3.97k Upgrade Release
Locked
Post by jussij » Wed May 02, 2012 4:49 am
This message is to announce the release of the latest Zeus 3.97k versions.
The latest Zeus for Windows 3.97k patch can be found here: http://www.zeusedit.com/z300/ze397k.zip
VERY IMPORTANT NOTE:
For these older registration key please install the Zeus 3.97i found here: http://www.zeusedit.com/zforum/viewtopic.php?t=6614
  3. Run the latest Zeus 3.97k installer and install the software into the original Zeus directory of step 2.
  4. Copy over the zConfig directory from now renamed directory of step 2 and paste the directory into the new Zeus installation directory.
  5. At any stage should you then wish to revert back to the older release, just delete the latest version and undo the rename from step 2.
Locked
