Zeus for Windows 3.97j Patch
Locked
Post by jussij » Fri Mar 30, 2012 3:11 am
This message is to announce the release of the latest Zeus 3.97j versions.
The latest Zeus for Windows 3.97j patch can be found here: http://www.zeusedit.com/z300/ze397j.zip
VERY IMPORTANT NOTE:
  3. Run the latest Zeus 3.97j installer and install the software into the original Zeus directory of step 2.
Locked
