Zeus for Windows 3.97i Patch
Locked
Post by jussij » Sun Mar 18, 2012 4:38 am
This message is to announce the release of the latest Zeus 3.97i versions.
The latest Zeus for Windows 3.97i patch can be found here: http://www.zeusedit.com/z300/ze397i.zip
VERY IMPORTANT NOTE:
  3. Run the latest Zeus 3.97i installer and install the software into the original Zeus directory of step 2.
Locked
