Zeus for Windows 3.97g Patch
Locked
Post by jussij » Thu Sep 15, 2011 12:28 am
This message is to announce the release of the latest Zeus 3.97g versions.
The latest Zeus for Windows 3.97g patch can be found here: http://www.zeusedit.com/z300/ze397g.zip
VERY IMPORTANT NOTE:
  3. Run the latest Zeus 3.97g installer and install the software into the original Zeus directory of step 2.
  4. Copy over the zConfig directory from now renamed directory of step 2 and paste the directory into the new Zeus installation directory.
  5. At any stage should you then wish to revert back to the older release, just delete the latest version and undo the rename from step 2.
Locked
