Zeus for Windows 3.96p Patch
Locked
Post by jussij » Tue May 13, 2008 12:06 am
To all registered Zeus Version 3.96 users,
The latest Zeus for Windows 3.96p patch can be found here: http://www.zeusedit.com/z300/ze396p.zip
As always, backup your current install before applying any patch.
IMPORTANT NOTE: This patch will only work for the version 3.96 of Zeus.
Users running earlier versions of Zeus and wanting to apply this patch will first need to upgrade their registration key to the latest version.
IMPORTANT INSTALLATION NOTE:
To install the patch do the following:
  • Make a full backup copy of the current Zeus installation directory
  • Unzip the patch file to write over the current set of exe and dlls files
  • Start Zeus and re-enter your registration details
  • Display the About dialog using the Help, About menu
  • Ensure the version listed is 3.96p
  • Ensure the registration details displayed are still correct
Regards Jussi Jumppanen
Locked
