Python code completion bug
aestes
Post by aestes » Mon Sep 21, 2015 6:45 pm
I am not (yet) a Zeus IDE user but am currently evaluating it. I believe that I am running the most recent release (3.97y). I have a python file I am editing and whenever I type something which would start code completion I get a debug window with several lines of python traceback ultimately ending with an error in the sphinx module which is part of the python 2.7 for windows installation.
I can't seem to paste any additional lines from the error file without tripping the spam filter in the BBS software but this outlines the problem.
I don't have a pythonpath registered in my environment but I suspect that the installed python is somehow interfering with the internal python scripting. Any suggestions on how to handle this are welcome.
Andy
Scripting Error :> Traceback (most recent call last):
Scripting Error :>   File "C:\Python27\python-2.7.10.amd64\lib\site-packages\sphinx\__init__.py", line 47, in <module>
Scripting Error :>     def main(argv=sys.argv):
Scripting Error :> AttributeError: 'module' object has no attribute 'argv'
aestes
Re: Python code completion bug
Post by aestes » Mon Sep 21, 2015 7:02 pm
I have discovered that if I rename my c:\python27 to something like c:\python27a so that the installed python sphinx module is not getting pulled in by Zeus then the code completion works properly. This does solve the Zeus problem but breaks my other python scripts. I don't have a pythonpath environment variable so the python folder name is probably coming out of the registry.
Andy
Post by jussij » Mon Sep 21, 2015 11:33 pm
Hi Andy,
As you have found out, it seems that the version of Python that ships with Zeus is running into the version of Python that you have installed.
Normally this would not cause an issues (as Zeus would just run the first Python found in the path), except that for Python code completion, Zeus uses Jedi to do the code completion, and that Jedi code is tuned to the version of Python that ships with Zeus :(
Can you tell me which version of Python you have installed in the c:\python27 folder by running this Python code:
import sys
print (sys.version)
This is the version that ships with Zeus:
2.7.8 (default, Sep 18 2015, 19:31:30) [MSC v.1500 32 bit (Intel)]
NOTE: The build time will be different but the version should be the same.
Also can you check the PYTHONPATH as seen by Zeus by running the following Zeus script:
import os
import zeus
try:
    python_path = os.environ['PYTHONPATH'].split(os.pathsep)
    zeus.message_box(0, str('\n'.join(str(path) for path in python_path)))
except KeyError:
    zeus.message_box(0, 'Error finding paths')
Just save this code to the c:\temp\test.py file and then run that file using the Zeus Macros, Execute Scripts menu.
When I run it I get this as the PYTHONPATH result:
C:\Program Files(x86)\Zeus\zScript\
C:\Program Files(x86)\Zeus\zScript\PyLib
C:\Program Files(x86)\Zeus\zScript\PyLib\modules
.\DLLs
.\lib
.\lib\plat-win
.\lib\lib-tk
As shown above I too have no environment PYTHONPATH defined, so you should see something similar.
PS: While you are waiting for a fix, you can turn of the code complete by removing the triggers. To do this just use the Options, Document Types menu to edit the Python Document Type and in the Triggers section remove the triggers.
Post by jussij » Tue Sep 22, 2015 6:21 am
In addition to what I suggested in my previous post could you also try this.
Use the Zeus, Tools, DOS Command Line menu and run the following two commands:
cd c:\
which python27.dll
Those commands should report this result:
cd c:\
C:\>which python27.dll
C:\Program Files (x86)\Zeus\python27.dll
aestes
Post by aestes » Tue Sep 22, 2015 12:27 pm
Jussi,
Python version is
2.7.8 (default, Jun 30 2015, 18:15:33) [MSC v.1500 32 bit (Intel)]
This is the result of the script (transcribed, I can't seem to copy from the dialog box):
C:\Users\adestes\AppData\Roaming\Xidicone\Zeus\zScript\
C:\Users\adestes\AppData\Roaming\Xidicone\Zeus\zScript\PyLib
C:\Users\adestes\AppData\Roaming\Xidicone\Zeus\zScript\PyLib\modules
C:\Program Files (x86)\Zeus\zScript\
C:\Program Files (x86)\Zeus\zScript\PyLib
C:\Program Files (x86)\Zeus\zScript\PyLib\modules
.\DLLs
.\lib
.\lib\plat-win
.\lib\lib-tk
Finally, the which command gave me C:\Program Files (x86)\Zeus\python27.dll
Andy
Post by jussij » Tue Sep 22, 2015 1:33 pm
Thanks for that feedback.
This is all a bit strange, since your feedback suggest this file should never be found:
But of course it was :(
I'll take a closer look at the Python code to see does some sort of special search for files at the C:\Python27\ location.
But I'm total at a loss as to why and how it actually managed to find that file :(
I don't understand what made Python to go looking for a file in this location :?
Thanks again for the feedback.
aestes
Post by aestes » Tue Sep 22, 2015 2:05 pm
Jussi,
It is a bit curious. I do not have c:\python27 in my path so it isn't finding it that way and it isn't in my pythonpath so it must be going through the registry. I actually have several versions of python on my system (anaconda 3.4, python 2.7, and ironpython 2.7 as well as a couple of embeded python scripting engines) but I haven't run into a case like this. I suspect that since Zeus is using (more or less) the same version that I have installed in c:\python27 then it must be going through the registry. I do have an entry at HKCU\Software\Python\PythonCore\2.7 which points into c:\python27.
Do you have the sphinx package loaded in your python environment? I found that if I keep c:\python27 as is and rename ...\site-packages\sphinx to sphinxa then the code completion works without error.
Andy
Post by jussij » Wed Sep 23, 2015 12:38 am
Hi Andy,
Thanks for posting your feedback. Much appreciated.
I suspect something in the Zeus's version of Python might be finding that registry key.
I don't think so.
Zeus only has a fairly minimal Python install, the components of which can be found here:
C:\Users\<Current User Name>\AppData\Roaming\Xidicone\Zeus\zScript\PyLib
I vaguely remember Zeus having issues with sites many versions ago.
I'm not really up to speed on how the site stuff works in Python but I think I had to add this file to the Zeus install to get things to work:
C:\Users\<Current User Name>\AppData\Roaming\Xidicone\Zeus\zScript\PyLib\site.py
Maybe something in that that file is causing this issue :?:
I'll so some research into this 'site' stuff to see if Zeus is doing something wrong.
aestes
Post by aestes » Wed Sep 23, 2015 12:29 pm
I think I see what is happening and it isn't anything Zeus is doing. It looks like the following:
You call into jedi_auto_complete, ultimately jedi (from docstrings.py) tries to load numpy to get NumpyDocString, NumpyDocString then tries to load sphinx. If Jedi can't find numpy it catches a loaderror exception (line 44 of jedi\evaluate\docstrings.py) and makes other arrangements. The problem occurs when numpy is available; it then tries to load sphinx. Sphinx tries to reference sys.argv which I suspect doesn't exist in your scripting engine so it throws an exception (AttributeError). I can fix the issue locally on my machine by adding an except AttributeError: in jedi\evaluate\docstrings.py at line 47 (and copying the two lines from the except ImportError: handler just above it). Of course, this could be on the next upgrade of Zeus (not sure how your upgrades work). It does slow down the load of the autocomplete slightly but allows the rest of the python implementation to work properly. A different fix might be to set sys.argv based on the Zeus command line but I don't know what sphinx will do with it.
In any event, I think I have a work-around on my side but this will pop up for anyone else who uses Zeus for Python and has a full python installation (which also happens to be found from the pythonpath environment or registry).
Andy
Post by jussij » Wed Sep 23, 2015 1:55 pm
Hi Andy,
Once again, thanks for your thorough analysis :)
Using the information from your analysis I found this related link: https://mail.python.org/pipermail/pytho ... 21095.html
It looks like it is a bit of a known issue for embedded systems :(
Can you tell me if this .\Zeus\zScript\jedi_auto_complete.py change also fix the issue :?:
#... Line 16 change
import sys
import zeus
#... Line 42 change
    sys.argc = 0
    sys.argv = None
If that works then I can make a similar change inside of the Zeus Python module itself by using code something like this:
Py_Initialize();
int argc = 0;
char **argv = 0;
PySys_SetArgv(argc, argv);
Is this the docstrings.py change you are planning to make :?:
try:
    from numpydoc.docscrape import NumpyDocString
except ImportError:
    def _search_param_in_numpydocstr(docstr, param_str):
        return []
# Zeus Start of Change - Ignores the AttributeError
        return []
# Zeus End Of Change
else:
aestes
Post by aestes » Wed Sep 23, 2015 2:13 pm
Unfortunately it doesn't look like it is that easy :) The series of errors are started by line 18 of jedi_auto_complete.py when it imports jedi_code so the fix happens too late.
      Zeus - Version 3.97y
      Copyright (c) Xidicone P/L 1993-2015.  All rights reserved.
Scripting Error :>   File "C:\Users\adestes\AppData\Roaming\Xidicone\Zeus\zScript\jedi_auto_complete.py", line 18, in <module>
Scripting Error :>     import jedi_code
Scripting Error :>   File "C:\Users\adestes\AppData\Roaming\Xidicone\Zeus\zScript\jedi_code.py", line 19, in <module>
Scripting Error :>   File "C:\Users\adestes\AppData\Roaming\Xidicone\Zeus\zScript\PyLib\jedi\__init__.py", line 41, in <module>
Scripting Error :>     from jedi.api import Script, Interpreter, NotFoundError, set_debug_function
Scripting Error :>   File "C:\Users\adestes\AppData\Roaming\Xidicone\Zeus\zScript\PyLib\jedi\api\__init__.py", line 24, in <module>
Scripting Error :>     from jedi.api import keywords
Scripting Error :>   File "C:\Users\adestes\AppData\Roaming\Xidicone\Zeus\zScript\PyLib\jedi\api\keywords.py", line 6, in <module>
Scripting Error :>     from jedi.evaluate import compiled
Scripting Error :>   File "C:\Users\adestes\AppData\Roaming\Xidicone\Zeus\zScript\PyLib\jedi\evaluate\__init__.py", line 68, in <module>
Scripting Error :>     from jedi.evaluate import representation as er
Scripting Error :>   File "C:\Users\adestes\AppData\Roaming\Xidicone\Zeus\zScript\PyLib\jedi\evaluate\representation.py", line 44, in <module>
Scripting Error :>     from jedi.evaluate import docstrings
Scripting Error :>   File "C:\Users\adestes\AppData\Roaming\Xidicone\Zeus\zScript\PyLib\jedi\evaluate\docstrings.py", line 43, in <module>
Scripting Error :>     from numpydoc.docscrape import NumpyDocString
Scripting Error :>   File "C:\Python27\python-2.7.10.amd64\lib\site-packages\numpydoc\__init__.py", line 3, in <module>
Scripting Error :>     from .numpydoc import setup
Scripting Error :>   File "C:\Python27\python-2.7.10.amd64\lib\site-packages\numpydoc\numpydoc.py", line 21, in <module>
Scripting Error :>     import sphinx
PYTHONPATH=.\;C:\Users\adestes\AppData\Roaming\Xidicone\Zeus\zScript\;C:\Users\adestes\AppData\Roaming\Xidicone\Zeus\zScript\PyLib;C:\Users\adestes\AppData\Roaming\Xidicone\Zeus\zScript\PyLib\modules;C:\Program Files (x86)\Zeus\zScript\;C:\Program Files (x86)\Zeus\zScript\PyLib;C:\Program Files (x86)\Zeus\zScript\PyLib\modules;.\;C:\Users\adestes\AppData\Roaming\Xidicone\Zeus\zScript\;C:\Users\adestes\AppData\Roaming\Xidicone\Zeus\zScript\PyLib;C:\Users\adestes\AppData\Roaming\Xidicone\Zeus\zScript\PyLib\modules;C:\Program Files (x86)\Zeus\zScript\;C:\Program Files (x86)\Zeus\zScript\PyLib;C:\Program Files (x86)\Zeus\zScript\PyLib\modules;.\DLLs;.\lib;.\lib\plat-win;.\lib\lib-tk
Macro script generated '78' Debug, Error and/or Warning message(s).
Andy
Post by jussij » Wed Sep 23, 2015 2:58 pm
Hi Andy,
Could you try the new scriptpy.dll found here: http://www.zeusedit.com/z300/scriptpy.zip
Just rename the older one out of the way as a backup and then unzip the new replacement dll:
c:\Program Files (x86)\Zeus\scriptpy.dll => c:\Program Files (x86)\Zeus\scriptpy.old.dll
This new version sets argc to one and the argv to an empty string on initialization.
The new dll will report as version2.04 in the Options, Editor Options menu, Scripting panel.
With a bit of luck it might fix the issue ;)
aestes
Post by aestes » Wed Sep 23, 2015 3:13 pm
Jussi,
Yes, that appears to have fixed the issue! I will play around with it today and see if I see that causes any other issues (although I don't see why it should).
Thank you for the all the work!
Andy
